All those posts were made before they released the bios that worked with Phenoms...no quad cores worked back then so I'm not sure what part of that thread you're reffering to when you get the 965.
Theres not much difference between the two if you overclock it I believe.
Seems they must've fixed it. Looks like it's the 940 that's the best CPU to have...
Well a C2 revision of the 965 will most likely work. The 980 is only C3, they moved to the C3 revision shortly after the 965 release and stopped with C2 production. So far the C2 965 is the safest bet if you want the best CPU for your board.
AMD Athlon II X4
620 2.6 GHz, 512 KB L2, Rev. C2, 95W, Socket AM3, ADX620WFK42GI 1102 Any
620 2.6 GHz, 512 KB L2, Rev. C3, 95W, Socket AM3, ADX620WFK42GI 1102 Any
630 2.8 GHz, 512 KB L2, Rev. C3, 95W, Socket AM3, ADX630WFK42GI 1102 Any
Can I ask a question of my ownI have been out of the loop for awhile, can I stick a bulldozer in my Crosshair Formula IV ?
I actually installed that beta bios by mistake when it came out, my system worked ok but obviously I never tried a Bulldozer in it, I cant afford to upgrade this side of Christmas anyway, but when I do I think I will buy a Bulldozer flash my board with the test bios again and try it, if it doesent work I will buy a new motherboard.
