errm ok m8 ,just pointing out its the same engine with the same mods making the same noise
I am not sure were the chav bit comes from, with nearly 200bhp with (imo) a good sound track, it aint no corsa
I reckon you hit at least a ton(certainly not very far from it) on 1 bit of that vid![]()
It doesn't sound the same. Probably because he has TB's. Yours is the same note but just gets louder when you press the throttle...
Many thanks!
Sounds like that setup is quite a bit of hassel, or is that to achieve good results? What I'm worried about, buying the ATC2000 is bad sound quality.
Did you have some kind of shielding over your microphones to stop the wind noise.
Ben.
rG-tom Where did you get the bullet cam from?
Hey 1CE, i had to do a double take when i saw the thread back on the first page
I use a JVC mini dv camcorder (DX107 iirc) with a "sportcam" bullet cam ( http://www.sport-cam.co.uk ), and 2 of these mics
The bullet cam and the two mics run into the line on the camcorder, one channel of sound per mic, mixed together in post processing.
Drexel, what inputs does your recorder have? It would be a bit easier than using a dv camcorder
Tom.
Sorry, missed this post.
It has standard composite video in and line-level left/right audio in. You wouldn't be able to plug you mics directly in as the audio inputs are line-level. Hence why I bought that 'audio patch lead', it has a mic and mini pre-amp built in, and outputs the audio as line-level.
Digital Recorder.
Audio Patch Lead.
