Butter or Margarine / Spread
Caporegime
17 Oct 2006
Ok I've seen a lot of butter talk lately in La Cuisine threads (mashed potatoes esp.) and I've been wondering, yes I'm sure we all use it for cooking and garnish etc but who all uses butter for something as simple as a sandwich or freshly baked crusty roll for accompanying say some soup, stew or pasta dish?
For me it's Bertolli (formally known as Olivio).
I prefer butter but it's usually Marge as its softer. I don't stock both, so unless I really want to go the extra mile and buy butter in then it's Marge.
Lurpak is one of my favourites but even that's a bit too hard tbh, flora light does the trick, if i'm not going to have the real deal i might as well make it light while i'm at it too. I would get the pro-activ stuff but for the price you could actually employ and immigrant to freshly churn some butter in the morning.
I like butter on warm bread rolls, but like others have said, it's too hard straight from the fridge.
I use Bertolli, but find that Tesco/Sainsburys' Olive Spreads are just as good.
I'm not keen on margarine like Flora etc - just tastes a bit weird to me.
I'd disagree on other shop versions of Olive spreads, I can tell the difference as Bertolli just tastes so much better to me.
I don't actually really like spreads, I don't have butter or marg on sandwiches that aren't made by me, because sandwich shops just put far too much on for me. A tiny thin layer is all I put on, so maybe that's why I can't tell the difference. x
Yeah I have to admit I do tend to butter both sides of the sandwich and not afraid to put some on :D
Always butter for me. No spreads touch it for taste. Put it in a butter dish = no spreading problems.
Butter dish noooooooooo! Sorry I still get flashbacks to lifting the lid (wasn't a clear glass type) on one that had been sitting on a table for a fortnight during summer... ..
I don't put Marge or butter in fridge. Butter is always impossible to spread.
Or is it the type of butter you use, in which case I would swap.
I keep both in fridge, butter for cooking is simple, slice and use. The Bertolli spreads easy straight from fridge. I'm starting to sound like an advert!
Butter definitely. I often buy Lurpack but only because it spreads easier. Olive spreads are nice too, though they pale in comparison to butter :)
I stock both proper butter and sunflower or olive spread. I use butter on sandwiches if it's gooey enough to spread, but my flat is usually quite cool so it's often a touch hard hence why I keep a spread aswell. I use HEAPS of butter in cooking though.
Have Norpak (Aldi version of Lurpak) taste the same and a lot cheaper and have Bertolli spread, very rarely use them, if I am having toast or crumpets will use it but I tend to just have bread spread free.
