Buying a Bass Guitar.
20 Feb 2004
Blyth, Northumberland
I have a Stagg P300 at the moment:
The neck and head are quite heavy which makes for some awkward playing especially when standing. Has anyone used a bass guitar that's better balanced, a one that has a lighter neck and head?
Is the problem that you have to support the neck with your fretting hand when playing? It could be simply down to the strap you use, originaly i had one made out of some fibre type stuff that just slid down, and made playing awkward, but i've got a plastic one, and a leather one (i think), both of which stop this happening, Might be worth checking out, depending what you currently use.
Yes, I had a nylon strap not so long ago that was terrible for sliding. I bought a leather one which is better but no matter how I adjust it the head insists on heading floorward :confused:
My budget's £500, I don't play anything in particular at the moment.
how about a fender jazz bass? im in a metal band and the bassist uses one, awesome guitars such a good sound very good output on them, finish is nice, by the fender strap with it aswell...
cant go wrong!
Ive got an Ibanez BTB406 which despite being a six string is less prone to neck dive than my P-bass, so I'd imagine the BTB404 should be fine. It sounds really good too, good eq and a nice tone to start with. I'm probably going to sell it soon though, I don't really need the two extra strings.
You could get yourself
Fender Active Jazz V
Fener Active Jazz
Fender Jazz with a Sadowsky outboard DI/preamp (just)
Fender P bass
Of course they'll all be Mexican Fenders but there still good. Of course i'm bias towards Fener i've played a fair few basses and i think Fender have the best look and tone and blance for my musical taste. However the BTB 6 string is amazing and for a long time i considered getting one.
Personly i'd go for a Jazz bass thinner neck off set body and lighter than a P bass. You can get the active mexican ones which have a bit of extra growl to them but would eat up your whole budget. you may want to consider saving a few hundred more and getting an American jazz.
Angel gives good advice.
Fenders have been the 'standard' bass sound on millions of different tracks over the decades and they feel right as soon as you pick them up.
I think I'm right in saying they were the first electric bass and so everybody has had to copy them.
However, if I had the money I would seriously consider one of these -
http://www.line6.com/variaxbass/
Yep Fenders were the first electric bass back in the 50's with the P bass. Its well worth playing a 51p even if its just the model they sound so Tinny and flat compared to modern basses.
The Variax bass is nice but for the 800-1000 i've seen them for i'd put my money in the Fender again. If you have a few good basses i'd get the Varaix but as a main bass i'd be a bit put off.
There's a pretty well-stocked shop at the Metro Centre with some Fender basses, I'll take a look and hold a few after my lesson on Saturday. I'm not looking for the best (or even the second best :p) at the moment but something that will last for a few years while I learn to play the instrument. I hope to be in a position both financially and ability wise to invest in a really good one in a few years, fingers crossed.
I go for the Ernie Ball strap from stringsdirect - its the only one I've found that doesnt leave the guitar at nipple height! Its amazing how so many shop-bought straps are ludicrously short - you cant get any Slash-style swagger with them at all.
The likes of Jimmy Page and Brian May always used thin leather straps that looked like belts to me! Not seen where to get them though.
lols i'm totally opposite, I can't help but find straps which just seems to be built for kiddie-nu-metalers :p
Guitar up by the chin is the only way for proper technique imo :D
Look a Fender Mexican basses, then play an american one and then go away and have a think about spending the extra money. Trust me if your serious about playing its worth the investment. I got a very nice Mexican Jazz which i really love, but sometime i wish i had saved a bit more and got the USA version.
Advanced techniques such as two handed tapping and slap alway sound off on a Mexican to me. Pickups aren't sensitive enough for tapping and slap can sound a little rough. But for true tapping goodness you want a Musicman Stingray with pizo pickup!
I find the sort of people that are into "technique" dont own a strap at all, which says a lot about their idea of the practicality of the instrument.
:D :p
If you're not 'into "technique"' at all then i'm confused as to how you'd expect to play anything at all :confused:
