I've never bought one before. Got a 2500k on a Asus P8P67 Pro board, is there anything compatibility wise that I should be wary of? Looking to get one around the 60gb mark, looking at the crucial m4 or the ocz agility 3 at the moment. Which one would y'all recommend?
Im going to use the SSD as my boot drive. Had my windows7 ultimate 64 bit pc for about 4/5 months, would I be better off doing a fresh install onto the SSD, or use the software to copy over my windows install? I want my pc to run fast, but if I'd see little benefit from a fresh install then I probably wouldn't bother
Also, a little bit random but most of the time when I turn my pc on it goes back to the bios screen twice before it goes to start loading windows. This means it takes a little longer than normal to boot up. This wouldn't remove the point of an SSD would it? Really don't have the time at the moment to go troubleshooting the issue.
Thanks.
Richard.
Thanks.
Richard.
