Bye Bye 2015 !
Caporegime
20 Oct 2002
Wish i was in a Ramen Shop Counter
So, 2015 is ending, or ended by the tie if you read this so post some pics! or make a 4x4 like this.
Cheers guys :)
What did you use for your 4x4 Raymond?
Photoshop plugin - Storyboard. It's normally used to create collages for blogs.
I cropped each photo manually to squares. Put 4 photos into the plugin to create 1 single strip. It makes the white edge for you.
Then put 4 strips through and chose the stack option.
There's probably a easier way to do that.
Automate contact sheet II in photoshop does exactly this, allowing you to set the number of rows, columns and the final image dimensions.
