Hi
I just came across this clever thing called Bye Bye Standby. Has anyone else seen this?
I put it in this sub-forum as expect many of you have plenty of devices which all sit there 24hrs a day, either on or on standby. TV's, pre amps, power amps, subs, HTPC's etc etc. This could save you a bit on those increasing leccy bills.
It costs about £20 for the pack with 1 remote and 3 plugs, good for loads of devices if you use multiple plug socket things.
There's even an add-on which lets you control in all from anywhere online
Opinions?
Q: What is Bye Bye Standby®?
A: Bye Bye Standby® is a brand new energy saving solution designed to reduce daily energy consumption of electrical devices. Bye Bye Standby® works by completely cutting power to the devices plugged into it when they’re not in use, thus saving the power that devices would otherwise have consumed in Standby Mode. Bye Bye Standby® is a new way to save energy, carbon emissions and money.
Q: How does Bye Bye Standby® work?
A:Bye Bye Standby® (BBSB) is a device that connects between the wall socket and an appliance which consumes energy unnecessarily. This could be an appliance with a standby mode, such as a TV, or an appliance which is always on when it could be off, such as a printer or wireless router. The BBSB device allows the user to have easy control over all these types of appliances. When they no longer need to use these appliances, such as when they are out or asleep, a single button can be pressed which physically disconnects the wasteful appliance so it no longer consumes energy. Pressing the button again reconnects all the appliances.
Opinions?
