c£1000 build... R9 290x lightning or gtx 970
The black/yellow build looks awesome.
YOUR BASKET
1 x OcUK Tech Labs - Custom Raijintek Triton Cooler £59.99
1 x Mayhems Pastel - Sunset Yellow Coolant 1L £14.99
Just saying ^
This would put Me off somewhat:
Customer Notice:
The unit comes with a Warranty Void Sticker covering the fill port on the main unit. This is to prevent novice users from opening the system. By opening the unit to add the dye, the manufacturer assumes that you have a level of expertise required to carry out the task.
Removal of the Warranty Void sticker will only void your warranty if signs of misuse or excessive modification is detected.
I think I'm going to stick with the aericool ds200 case, I like the sound of leather on the outside and the sleek look. The temperature reading and controls on top are cool too.
I'm not missing something am I? As long as it fits the case isn't a huge deal?
If you like the Aerocool case then everything will fit ok.
Customer Notice:
Agreed but getting the OcUK custom version in the basket takes care of that:
The standard Raijintek unit allows you to modify the appearance of the unit using the included dyes. The only downside to this is that Raijintek warn novice users away from opening their units.
Would need fans adding though, just noticed.
Ah didn't notice that OCUK fill it for you. The picture shows 2 fans fitted though on the rear, and mentions it in the last paragraph.
Hmm ok last few questions
1.the case..Its just got to fit, right? I really like the aerocool ds200
2. I'm happy to build my self, last time I did it was 7 years ago but being an engineer in not afraid.. However if overclock build I get a nice warranty... Do you think its worth it?
Well probably buy tonight
If you are happy to build it yourself then do it. You will save around £60+ that way. You still get the individual warranty with each component.
Don't forget the free shipping with a Superflower psu and case 'SFCASE' at checkout. And the cashback offer as well with a 'k' cpu and board bundle from the toptechcashback link.
