C++ and Header file help required
  • Thread starter Thread starter k++
  • Start date Start date
k++
k++
5 Oct 2004
London
I have a main c++ file, for example called a.cpp
I also have two other files, b.h and b.cpp and a.cpp includes b.h
a.cpp
Code:
#include "b.h"
using namespace std;
int main() {
  TestClass test (100);
  return 0;
b.h
Code:
class TestClass {
public:
  int value;
  TestClass();
  TestClass(int new_value);
b.cpp
Code:
#include "b.h"
TestClass::TestClass() {
  value = 0;
TestClass::TestClass(int new_value) {
  value = new_value;
Please could someone explain why when I compile a.cpp I get the error "Undefined Symbols"
referring to
Code:
TestClass(int)
If I try to do exactly the same in the b.cpp I don't have any problems, why is a.cpp unable to use the class from b.h which is defined in b.cpp?
regards
Is it because you have #includes instead of #include?
Just guessing as I haven't done any C for 15+ years and can't remember for toffee!!
Wow I'm dumb, my makefile was causing the problem
This thread can now be deleted :)
This isn't my actual code, I just typed it into the message box as an example. I seem to have fixed my program, for now :p
Thanks for the quick response
