C# Multi-Tetris
1 Feb 2006
Hi,
I created this a few years ago in Delphi just for fun and decided to convert it to C#:
Updated version
sound = 9loops-> "keep it simple" from FLStudio.
done a android version
Updated mobile test:
mobile test: here
If you try it can you post how it runs, only tested it on an old nexus 6, thanks.
Added a few things:
projected block position
Distortion shader to background so it looks less static
block fast drop
Added screen buttons for fast drop, block rotate, slice selection, sound on/off and start/pause.
