C300 on marvel to intel
7 Jan 2010
Up NORTH
Hi forum,
If I move the c300 from the current marvel 6gbs connection to intel 6gbs will
It cause me problems or will I need to reinstall windows,
By board is p67 deluxe
Connect a spare SATA drive to one of the Intel ports, put the controller in AHCI mode and boot from the c300 on Marvel. If you can access the spare SATA drive in windows you should be ok to move the c300 over and reboot.
If you can't see the spare SATA drive (in disk management), put the latest Intel chipset drivers for your board on.
Cheers for that
