hello.,
im new to ssd's but i think that something is wrong with this c300 64gig ive recently installed, its the boot drive on a new win7 64sp1 msi 870a-g54 system..., by wrong i meen i havent done something right
....., it has got a sata3 white/cream cable plugged into the same coloured port and TRIM is enabled. the read speeds are in the right area but not the 350ish mark, however the right speeds seem way off..., in terms of usability, it feels fast and responsive. AS sdd reports a 31k cluster offset/allignment @ 4k cluster.., i dont know what this meens but it reports as 'bad' could this be important?, the pic should explain more than i can,
thanks for your time
....., it has got a sata3 white/cream cable plugged into the same coloured port and TRIM is enabled. the read speeds are in the right area but not the 350ish mark, however the right speeds seem way off..., in terms of usability, it feels fast and responsive. AS sdd reports a 31k cluster offset/allignment @ 4k cluster.., i dont know what this meens but it reports as 'bad' could this be important?, the pic should explain more than i can,thanks for your time
