cable dsl router setup help
  • Thread starter Thread starter 233
  • Start date Start date
233
233
21 Nov 2004
Wishaw
just got a netgear WPN824 V2 router for the house,
cant get the bleeding thing to work :(
not in terms of wireless its fine both laptops can see the router (network)
my problem is that i cant connect to the internet from the router
If i connect my pc directly to the cable modem web is fine(as i'm doing now
if i go through the router i cant conect to the web but i can ping the router and log on to the router quite happily
below are the settings i'm using
its ntl 20 meg connection btw
no login for the connection
no acc or domain name
dynamic ip from isp
dns automatically from ip
and routers mac address
also tried my own ip
81.101.54.184(ip)
255.255.252.0(subnet)
81.101.54.1(gateway)
with dns's of
62.253.162.237
194.168.1.237
no joy guys
any suggestions
i spent an hour with netgear tech support who suggested dynamicly from isp all the way and they were as much use as a chocolate tea pot (2nd line support were supposed to call be back 3 hours ago but never did)
c;mon ocuk help a networkphobe out here :)
Turn off your cable modem for 20 minutes. Or, use the MAC address of your PC network card in the router then restart router and cable modem. All other settings on auto.
Look on the Setup>Basic Settings page. At the bottom. Use either 'Use Computer MAC Address' or 'Use This MAC Address' and manually enter the MAC address of the network card in your PC.
still no joy :(
any other suggestions
funny thing was it was working fine yesterday
i moved the router recabled it didnt work straight away so checked the settings and changed em and now it doenst work :(
gutted
still no joy :(
gutted
No joy ? What did you try?
still no joy :(
gutted
Turn off all computers
Unplug the modem (power)
Reset the router
Leave for a few minutes
Plug modem into router
