Cable help 4pin mobo - 4pin extender
7 Jun 2010
Sussex
hey guys i've kinda finished sorting my cables out in my new case but the 4pin ATX connector for the mobo is too short to route from the bottom psu through the case and out again at the top, i've looked on the OCuk store but they only have a 4pin to 8pin extender, has anyone got any ideas if anyone makes what i'm looking for? or would a 8 pin one work anyways, ( am kinda against the 8pin since the space where the plug is located is very very tight indeed)
any ideas would be much appreciated
i'm gonna go bump this with, i'm guessing that no one makes such a extender? so what would be my options?
new mobo or new psu? or both lol
hey stulid, thanks for the reply, so, would i just fit my 4pin into the 8pin block, and it'd work? sorry am a complete novice with cables and such lol
Yea, this one OCUK will work fine for you needs, you only need to use 1 of the two sets of 4pins. The benefit of going for this is that it will work fine now, and if you get a system which needs an 8pin in the future - you can reuse it.
If you do go for one from elsewhere, just make sure it is a decent brand. Don't go mad, but don't just go for the cheapest chinese-made cable you can find.
