1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Cable help... for optical drive...
Discussion in 'General Hardware' started by sugoi, 24 Dec 2014.
  1. sugoi
    Gangster
    Hi, I have a problem, I just bought this.
    http://www.overclockers.co.uk/showproduct.php?prodid=CD-158-SA&groupid=701&catid=10
    But not sure what cable is needed for the port on the left, the right L-shaped port is SATA, but what do I need for the left, im assuming it's for power? But I don't know where i can get one, or what it's called.... I thought I only needed the SATA, but it won't boot or find it. Its slightly smaller than the SATA connections...
    Image attached below:
    http://i.imgur.com/U0hjUmO.jpg
  2. RJC
    Don
  3. Idleman
    Capodecina
  4. sugoi
    Gangster
  5. Idleman
    Capodecina
    If you google slimline sata to sata , is another alternative.
