cable management improvement
11 Jul 2005
I have just drilled some extra holes in my Coolermaster case for improved cable management. I now need something to go over the edge of the holes to protect the cables.
This is usually like a plastic strip...but where can I buy some...any ideas anybody?
Cheers:confused::confused::confused:
If you have a ******s store near you, it would be worth a visit and talk to the staff...******s seem to have all sorts of kit available...it's finding it that's the problem...
