Cable management tutorial ? :o
Perhaps you can get some cable tie bases that are self adhesive?
Thing is this wasn't a cheap case :O i am hoping on getting a new one soon, fractal i think i decided on, hoping that has cable management features! :o
Me too, I finally ordered and its here tomorrow! It seems to come included with some ties and it has the ability to store the PSU cables behind the MB so its got the potential!
There is no "tutorial", just look at the case in hand, work out where wiring can be hidden, extend where necessary, and above all, try to keep the airflow clean (so no hiding all the cables in empty drive bays in front of the intake fans!
Have a look in my (now ancient) thread, here
instead of those sticky things, you could just use a long cable tie or a piece of string going around the bits where the side panels clip into the case, making a bar near the base or top of the case
