Trying to sort out a friends dodgy virgin connection, it's only been duff since january
Connection is stupidly slow, most things time out, even the modem info pages, BUT this forum is fine
, not a clue what is going on. I can't even drag the machine home as it's the net connection that is busted, machine is running fine.
Any ideas? Not dealt with cable stuff for a while so i'm out of ideas (apart from the BFH)
Cheers
2007-03-25 13:29:406-Notice0x045A80E4TLV-11 - unrecognized OID
1970-01-01 00:00:153-Critical0x040D9A2CDHCP WARNING - Non-critical field invalid in response.
2007-03-25 13:22:256-Notice0x045A80E4TLV-11 - unrecognized OID
1970-01-01 00:02:213-Critical0x040D9A2CDHCP WARNING - Non-critical field invalid in response.
1970-01-01 00:02:133-Critical0x04E33948No Ranging Response received - T3 time-out
1970-01-01 00:02:083-Critical0x0501BDC8SYNC Timing Synchronization failure - Failed to acquire FEC framing
1970-01-01 00:01:583-Critical0x0501BD64SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:01:573-Critical0x0501BDC8SYNC Timing Synchronization failure - Failed to acquire FEC framing
1970-01-01 00:01:573-Critical0x0501BD64SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:01:563-Critical0x0501BDC8SYNC Timing Synchronization failure - Failed to acquire FEC framing
1970-01-01 00:01:453-Critical0x0501BD64SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
Cheers
