Cable question for output on monitor
11 Jul 2003
Telford//west mids
OK i have the Asus VG236H 120hz and use it for gaming at the moment i have the DVI-D cable installed will i benefit more from a HDMI cable fitted?
Videocard in sig.
Thanks.
For clarification with DVI 120Hz only works with dual link so as long as you're using a dual link cable (I assume one was supllied with the monitor) and a dual link output from the GPU then all's good.
Both DVI connectors on the GTX 580 are dual link so you should be able to use either.
