Cable routing the Raven rvz
5 Aug 2018
So I just finished stage 1 of my newest build, a silverstone raven 3 4K VR rig. Here’s the current specs, then I’ll get onto the cabling of doom:
i7 8700k
Asrock z370m ac (non gaming)
250gb m2 Samsung evo 970
2x8Gb vulcan Tforce 3200Mhz memory
Phanteks ph-pc12ls cooler
And...
Evga gtx560ti Superclocked
Cable management has been ok so far. The 24pin atx clashes with the heat pipes on the cooler, but I threaded the cables on the unbraided part of the cable. Other than that I doubled the cables back on themselves where possible to shorten them and crammed a lot in a small void at the end of the graphics card.
Here comes my question! Phase 2 will add a 2.5 inch SSD and a 1070 Ti. The ssd power cable has 2 spare sata sockets and takes up loads of room. The 1070ti is full length and eats my cram space too. Ideas?
Anyone got any routing tips for this case, or should I get 30cm cables where I can? The PCIe are waaaaay too long, 5cm is fine...the card ends next to the psu!! where can I get some made to order?
Pics to come...
