Hi guys,
For the past few weeks my internet has been getting so slow (im on blueyonder 10mb) I used to get 1200kbps on downloads easy and no lag/high pings at all but now I am lucky if I get 100kbps and multiplayer games are unplayable. I don't have spyware/adware etc and am 100% sure its not my pc.
Anyway to cut a long story short I contacted their support and they have done everything they can check wise at their side and they can't see a problem so they are sending an engineer out tomorrow.
I just wanted to know if there was anything I should ask the cable guy while he is here? Anything in particular they can even do? I just don't want it to be a wasted call out.
Thanks in advance
Thanks in advance
