Cable Tidy Advice
19 May 2004
Horsham, West Sussex
Bulding an 'under the telly' gaming PC.
Using a Grandia GD04 and space is fairly generous but nothing like I'm used to.
I do keep my tables tidy using ziplock ties.
But does anyone have any clever ideas for the front panel wires. They are about 4x longer than I need. Of course I can try and wrap them in hank and ziplock and whilst functional it doesn't come out too neat.
Just wondering if anyone has any clever tips - or is just 'hank and ziplock' the best appoach.
Cheers,
Nigel
I either fold them over to get the right length and then slip some heat shrink over them all and that makes a single length with the slightly wider part where the folded wires are, looks neat and tidy
or
Make the wires shorter by either de-soldering them from the switches/plugs and cutting to length or just cut/solder/heat shrink them.
