It is with the EK quantum vector2 Strix tuf 4090 and the EK quantum vector2 FE 4090 without the active cooling backplatenot compatible with EK water blocks though![]()
I bit the bullet and decided to get a 180 degree adapter for my 4090 with a EK waterblock and a coloured cable to match my other cables, and a second adapter for a friend which helps divide the delivery and import cost between 3 items and not just 1.I got the email the other day, and I like the tidy look of the adapter, but in all honesty I've got used to the look of my current cable setup and there will only be more risk involved having extra connections on a 600W cable. And at $40, think I'll give it a miss for now.
Would the 90 deg one not be a better option, same as what I got?
Your fans could do with a cleanI have the 180 degree one and there's just one problem with it: it's fractionally too big. It pushes against the CPU fan and there's a big gap - perhaps 5mm - between the backplate of the GPU and the connector.
Maybe, but it has yet to arrive. (I ordered both.) But I prefer the 180 degree adapters because they do a better job of hiding the cables.
BTW have you thought of routing all that tubing via the back of the case?
Sure is , check abovenot compatible with EK water blocks though![]()
insane lol. Both cabled and EK confirmed it wasn't. Oh well. I've been building this long enough now. Im done with getting more parts! Finally leak testing itSure is , check above![]()
EK don't seem to know what will fit what tbhinsane lol. Both cabled and EK confirmed it wasn't. Oh well. I've been building this long enough now. Im done with getting more parts! Finally leak testing it
they were on the Asus PC DIY FB page saying the ABP wont fit with the Z790 Hero either so had to show them the errors of their ways showing it does indeed fit
for me its more paying almost the same again for shipping that puts me right offMaybe at half the price but I don't really need one as I have room in my corsair 7000d airflow.
