I agree - I’m quite suspicious.
I’m having another look round for a different tradeperson
I had my SKY install today and had to accept liability/risk for the drill-hole the installer made through wall just to the right of above pictured door frame, in case there was a heating pipe,A lot of the ones I have asked aren’t responding at all (is this because they can’t be bothered with such a “cheap” job)
I get that with Sky and OR/their subs (because they're not really "professionals" a such)I had my SKY install today and had to accept liability/risk for the drill-hole the installer made through wall just to the right of above pictured door frame, in case there was a heating pipe,
so I can understand reluctance companies might have, for cable installs.
(my new patent) I'm not sure why they don't put a piece of conductive tape on the plastic heating pipes
[only issue I have now is that apparently may take 3 days for telephone number porting to sky digital voice]
Have you tried your Xbox upstairs on the new line? Or another device?So finally had the 1 cable run done last week (£180 but so worth it!)
Problem is I have an ASUS motherboard (Prime B550M to be more specific) with built in networking and am still experiencing some issues connection wise (though latency is improved, though still not as good as the wired Xbox SeriesX downstairs!) - does the WiFi card also have an impact on the Ethernet in anyway? Really don’t want to have to get a replacement networking card (as it would be awkward, though not impossible to do)
Reason why I ask is I had one PC that I had to return (for other reasons) but that one was fine from a WiFi perspective.
Trying to figure out a solution for the poor WiFi still - due to the cost, I couldn’t get an AP done (was wondering if would be possible to use the cable to connect a router or something that could do that and also connect my PC at the same time). Wouldn’t be against it were it not for the ridiculous quotes I was getting to have one or two installed.
That’s a good idea - I’ll try connecting the Xbox firstHave you tried your Xbox upstairs on the new line? Or another device?
It'd be worth checking that first before considering either a network card for the PC or replacing the motherboard.
| 29/05/2024, 00:35:55 | Network interface eth1 down |
| 29/05/2024, 00:35:58 | Network interface eth1 up |
| 29/05/2024, 00:36:09 | Network interface eth1 down |
| 29/05/2024, 00:36:13 | Network interface eth1 up |
| 29/05/2024, 00:37:07 | Network interface eth1 down |
| 29/05/2024, 00:37:10 | Network interface eth1 up |
