Caddie or NAS?
6 Nov 2002
Brum, Brum, Brum, Brum....
hi guys, struggling to decide whats the best approach for me.
i have 2 desktops, 2 laptops and a pda, all with wireless functionality
what i want to do is make certain files available to all of them at any time by plugging something into the back of my wireless router, essentially keepsing my music, videos, pictures etc on a central server.
it would also need to be a Print server so that i can print everything to my laser printer
i'm guessing the only real option is to get a NAS, as the caddie would only serve files to the pc its connected to and would not be connectable to the router?
if so i think something like the synology, which seems to be a good product but with only a single HDD space would be a good option.
another option allowing raid of those all important files would be the dLink, although i'm not sure what limitations the phrase "UPnP AV compatible network media players" causes (i assume this means any pc and my dell x52v would be ok though).
i'm leaning towards the dlink, but the synology seems to be a popular product.
Thoughts?
I'd get a NAS, any PC on your LAN can access files on it, plus that D-Link has a printer server function. Also UPNP media but you'll need a UPNP compatible device.
I have that D-Link DNS-323 btw.
A caddy is basically just portable HD, so if you need to share files the host PC will need to be switched on, or you'll need to unplug it and fit to the other. Bit of a chore.
Fine, switch it on, access files. The fan is a little bit loud though (compared to a quiet HTPC) so store it in spare room, under the stairs..does what it's supposed to do. Wouldn't mind replacing the two 320GB with two 500GB+ later on..
ok as I've done both a windows server box (with caddy) and a synology nas and I have pda, laptop and pc's to connect to them.
The pda (wm5) is a pita to get to link into the nas (only got ftp working so far) where as its a piece of cake to link into windows, set up a lovely windows share :)
