Calisthenics - Who's using this as a core exercise?
8 Jun 2006
Hertfordshire
Hi All
I complete the Brighton Marathon last month after a long time training, now I can run for hours but can't do a unassisted pull up :(
So I've started to watch some Youtube feeds and got "How to build strong & lean Bodyweight Muscle" by Anthony Arvanitakis, so of the advanced exercises are way out of my strength but you have to start somewhere
Just wondered if there's anyone else doing this on the forums? Just trying to get some core strength back
:D
I did try it for awhile as my gym was a crossfit hybrid type of affair. Wasn't interested in it though in the end. It is useful for building core strength but personally i found there isn't anything it offered me over lifting weights. Infact i would say it hindered me in some regards because it can be hellish on your joints.
Best thing for pull ups is just keep at them and do back exercises too. I gradually added weights over time and now i can breeze through them.
I think it depends on which exercise you do and how strong/weak your joints are then you build you plan round that I guess
Honestly most of the core stuff is just about doing it.
Sounds silly but they are probably the most neglected body part, so they tend to be super tough to start but you would be surprised at how quick you see improvements.
Push ups, pull ups all have that tough beginner entry but decent progress vibe to them.
It never hurts to add them to the end of a routine
Calisthenic bars and rings look like bar work but fun, really want to get into this now I’ve freed up my time from marathon training
I've done solely home bodyweight routine for 3 months now.
I started with an upper body/lower body split, working out 6 days a week, but as I was also on a calorie deficit (trying to lose body fat at the same time as gain strength) I was getting burned out. So I switched to a Push/Pull/Legs x2 routine, so each group of muscles were only done 2x a week instead of 3x.
The equipment:
- a pull-up bar cost me £25
- resistance bands - I purchased 2x Purple (Large), 1x Small (Red) 1x Extra small (yellow), cost me about £20. The resistance bands were used to either give me assist on pull-ups, pistol squats, used as resistance in push-ups, shoulder press, lateral raises etc.
My routine was something like this: For all exercises I did 4 sets, and reps from 5 reps to 10. I started at 5 reps, worked my way up to 10, on all sets, before increasing the resistance/decreasing the assistance and starting at 5 reps again. Use as many bands as you require to get the right level of assistance/resistance.
I found this routine on Reddit, which worked wonders:
Push-day:
Push-ups, with resistance bands (youtube resistance band push-ups for example of how to do this)
Shoulder press with resistance bands (same as above, youtube resistance band shoulder press), can move to a single arm variant when it gets too easy
Lateral raises with resistance bands, hold one end of the resistance band down with the opposite foot, then typical lateral raise movement with the other end
Pull-day:
Pullups/chin-ups (rotate, chins important for biceps) with resistance bands used for assist (tie the resistance band around the pull-up bar in a loop-knot, put one foot/knee through the loop to give you assist)
Bent over rows with the resistance bands as your resistance. Hold one end of the loop down with both your feet, about shoulder width apart, lift the other end of the band(s) toward your stomach whilst bent over.
Inverted rows, using a broom (or the long bar part of your pullup bar) placed between two chairs
Leg day/ab day:
Resistance band aided pistol squats, I did this by using the resistance bands tied around my pull-up bar in the same manner as with pull-ups assistance, but instead of putting one knee through them put both legs through them (well, sat my bum back through the loop of the bands) so they are supporting you from underneath (placed just under your bum). Start with just regular bodyweight squats if the pistol squat with all bands as assistance is too difficult.
Edge of bedframe/steps Calf-raises using a backpack filled with whatever heavy stuff you can find at home (I used bags of rice)
Knee-raises using the pullup bar, with the resistance bands tied to something behind me and put around my ankles, so it gives me resistance as my legs are coming up (works abs)
Planks/side-planks hold for as long as you can
Hamstring curls - lay down on the floor on your back, with your bum raised, one leg used as support, and (whilst wearing socks on a wooden floor or having something underneath your feet that is slippery), extend one foot out and then bring it back in towards you, all whilst your working foot/heel are still touching the floor. This works your hamstrings and glutes, and you can make this harder by tying resistance bands to a heavy object/door handle and putting the foot you are working through them to add resistance. (Here's a 2 legged example: https://www.youtube.com/watch?v=oimeUrwxEo0)
This routine will work all your major muscles. Shoulders (all 3 sides, front, back, side), your back, your chest, your biceps and triceps, abs (plus obliques), all of your legs etc. Anything specific you want to work that isn't covered can just be added on.
Wow thanks for taking the time to post @twistedheat im looking at resistance bands along with the other small bits of kit skipping rope etc so when I’m away from home or at the weekends I can just train
How have you found the journey since you started, have you progressed well and built lean muscle, I’m about 5’11 and around 12.6/8 stone I just want to loose some fat around the stomach/sides (there not a great deal as I’m a runner) and build my core strength
Yeah my progress has been pretty good so far. As I mentioned I'm on a calorie deficit as I have similar goals to you (lose some fat in the midsection, whilst gaining strength), so whilst my muscle gains have been relatively minimal to average it's not a surprise given my calorie deficit. I've gained about 1/4" on my arms, 1/2" inch on my upper legs, whilst losing around 2.5" inches around my midsection. This is in the last 2 months since I started tracking those three areas. The scale shows me down only 5lbs, but the difference in the mirror is significantly more. Likely as I've gained some muscle, and lost more fat.
As ever, you have to think of the exercise you do as the catalyst that starts/allows the process of change, but the actual changes will happen by way of your diet. High protein, low calories, if your goal is to lose fat.
Follow fitnessfaqs on YouTube.
I've played around with it but nothing more, and there's only so much you can do for your legs with just body weight (I can pistol squat, shrimp squat and all that quite easily)... that said there are various things that cross over into yoga (since the modern practice at the advanced level is essentially gymnastics + mindfulness) and so I should probably work on some of calisthenic progressions since they're typically more systematic and programmed in a straightforward way.
Thanks! Subbed
I've been doing it casually for a few years now, it's immensely excellent and much better than just going to a gym and working weights. You build functional strength and condition your body into working completely as one unit.
My goal currently is the planch and muscle up. I can back lever OK and pseudo planch hold as well as L-sit hold but front lever is not quite there yet.
ThenX
FitnessFAQs
Austin Dunham and AthleneX are all the ones I started out watching and then just figuring out my own routine.
Dragon flag is an advanced move if you have decent core stability, and will make those abs burn better than any "normal" abs workout. It is also a complete full body workout essentially.Most important of all, Ecentrics above anything else, keep the descent SLOW and under control. Time under tension will show better benefits than just thinking you need to do the most reps. Remember this isn't gym workout, TUT and ecentrics matter more than anything else.
You also don't need to bother with specific days for legs, arms etc, again it's not a gym session. You can workout every muscle group in one session that lasts 30 mins in total, twice a week with 2-3 days rest depending on your burn level as fibres re-organise and strengthen.
Goes without saying, nutrition is paramount, make protein based smoothies if needs be to supplement additional intake to usual meals to grow those fibres better. I custom smoothie my own with chia seeds, flax seeds, peanut butter, fruits chopped up, berry granola, spirulina powder (cyanobacteria) and milk. Works out around 900 calories per shake.
The great thing about calisthenics is it can be done anywhere any time. Making breakfast in the morning? Bust out a set of dips on the kitchen cornertops, sat at the dining table? Drop a few inches and do Australian pullups off the table edge, out and about and have 5 mins? Do a set of pistol squats.... And so on.
Interesting thread!
Like a number of others here, I have also embraced calisthenics at the heart of my training.
I have done so after many years of weight training.
Sadly, a change in circumstances meant that I had to sell all my home gym equipment (rack, bench, barbells, plates, dumbbells, weight vest, weight vest plates, many other nice bits of kit), and use the room for something else.
I tried to fall-back on using a few commercial gyms in my area, but I have discovered that nowadays, a commercial gym is not for me. They are simply too busy, even at "off-peak" times. It appears that gym culture is wildly popular these days -- much more so than a decade or two decades ago. At times the gyms I tried were so mobbed is was actually ridiculous.
So, my training now consists of:
  • Calisthenics in the lounge.
  • Running, jogging and calisthenics in the park (grass football pitches and main park area), at extremely early hours, when no-one is about, and I can get the pull-up bar and dip bars to myself.
  • Hikes and rucks to supplement the above, also at extremely early hours. I drive to certain preferred locations.
I'm not sure how this is going to work in the winter / low-light times of the year, but right now (Spring/Summer) it is working well.
My training is more spartan and utilitarian than it has ever been, and yet I am enjoying it more.
In terms of specifics, I only really train very mainstream calisthenics movements. These work fine for me.
i.e., my sessions predominantly consist of selections from the following, dependant on what I want to do that day:
  • Jog/run/walk/hike/ruck.
  • Bodyweight squats.
  • Bodyweight lunges.
  • Bodyweight rear foot elevated split-stance squats.
  • Pull-ups or chin-ups. (I choose one and specialise on it for the session.)
  • Press-Ups or Pike Press-ups.
  • Leg raises (from bar or dip bars).
  • Simple plank variations.
  • V-Ups.
  • Hollows.
Looking ahead, I may invest in a single kettlebell or a single dumbbell, as I could accommodate one of these into an unused corner in the lounge.
A change in circumstances has really opened my eyes as to just how little equipment is actually necessary to continue to train and get at it on a regular basis.
All the best troops.
Hi All
:D
Here are the OG's
Watch and learn padawan, learn from the masters
Interesting thread!
  • V-Ups.
  • Hollows.
I have a single kettlebell and a two dumbbells, as well as a fold away pull up bar. I've found I don't need anything more than that.
I quit the gym last year for the same reasons.
Can anyone recommend any apps designed for calisthenics? I’m a total noob so wouldn’t know where to start.
Just my own personal opinion here mate, but I personally don't think you need app guidance -- or much book, article, forum or YouTube guidance -- for regular calisthenics/bodyweight training.
Consider those guys in the video above.
It is highly unlikely that they ponder over apps, training manuals, articles, YouTube videos, forum posts, and so on.
They just get after it, and often.
So, the main thing is to just get after it, most days (not all days) per week.
Only through doing sessions will you get a feel for your body, and where your strengths and weaknesses are, and what the movements feel like.
I suggest a 1 hour session most (not all) days per week.
The great Ross Enamait (one of my favourite formative physical training influences in the 2000s) advised to not get into a cycle of "paralysis by analysis", and I often have to remind myself of that to this day.
So, TLDR, my advice is to just get after it.
At most, you could maybe YouTube one movement per day to learn some of the ins-and-outs of what a good version of the movement might involve, but even then, you can use your intuition and get a feel for all the movements yourself.
All the best with your training.
PS: :D
If you are looking for some materials, and are willing (or looking) to put a little bit of money down, my personal tip is to invest in all of Ross Enamait's materials, available here. I priced up his entire set of materials, and the total price, at time of writing, was a frankly insanely low ~$75 USD (~£55 GBP). Never Gymless is the one that focuses on calisthenics. It's a one off purchase, and you keep the materials. You don't subscribe to anything. Also, you get his entire works for what is often the price of what is one publication from some of the high-profile people in this space. Also, compare and contrast the approach of Mr Enamait to the rampant money grabbing and subscription based services from so many "influencers" in the fitness space. Just some food for thought.
Outside Ross Enamait's materials, I also like those by Tactical Barbell (written by pseudonym K Black), and available here. Again, these are very affordable and are written with authenticity.
