145,000
No history of it ever being changed. I have been meaning to for the last year![]()
Change the engine for sure.
145,000
145,000 is nothing, its only just warn in
Whats wrong with just changing the head?
I had already asked the garage to fix it, so I cant just replace the engine/head etc now.
My issue is that I dont want to be told the cams are bent
So how likely is it & can I tell if i'm being lied to?
laber costs will be much the same
Hows that, you don't have to undo the gearbox, half the wiring loom or most of the cooling system, a head could be swapped in less than a few hours, takes more than that to get an engine out put the new one in line it up with the gearbox and get everything re-connected before you even know if the thing will work.
thats if your changing the engine
but if your putting in new valves its much the same
Why did you waste out time by asking when you've already made the call :/
The cam belt has gone on my misses astra (was my astra so i'm covering the cost).
Its been in the garage a week, they have quoted £700 - £800 as all 16 valves were bent.
How is this so? Surely for all this to happen, all 16 valves would have to be in the down position when the cam belt failed?
Just a minor issue I know, but I didn't think that there was any point of the firing cycle were that would be the case...
