Cambridge Audio DacMagic xs hssing issues
10 May 2012
North London
OK so i have one of those USB DacMagic from Cambridge Audio to use with my lappy and Headphones , but all I'm getting is a fuzzy hissing noise , anyone know how to fix it please ?
OK It's a DacMagic xs , OK so I did install the Driver from CA's website and now everything seems fine :), should I also install the ASIO Drivers too ?
No harm in installing asio drivers as well but it will only work if your playback software supports asio output. AFAIK jriver, foobar and winamp have asio or wasapi plugins.
When I tried the sound with ASIO it was a better sound to my ears,
you avoid using the windows soundmixer, or it's potential re-sampling (eg 44.1 Khz->48Khz) or floating point translation.
(gives lower latency too but not important for music streaming)
(@danoliver1 don't know if you have tried https://www.vb-audio.com/Voicemeeter/banana.htm, but seems this may ensure spotify/other sounds go exclusively to a soundcard ?)
you can try a low impact equalizer
Do you think that equalization algorithms/options in player to compensate for dac/headphones is really viable in a portable player or does it significantly impact sound quality ? (so you cannot really make up for any deficiencies in headphones or dac)
[I had a dacmagic XS in audition with a MEE matrix headphones but resorted to 'Room EQ wizard' to try and improve this 'bright' dac, which I eventually returned]
