Camcorder webcam question
19 Aug 2004
Stockton-on-tees
Is it possible to use a camcorder as a webcam via USB? if so what would you need to do it. bit of a strange question i know but my dad is wanting to know
hmm I think you should just be able to use it via s-video cable....
So your graphics card obvisiously needs a s-video connection...
You plug in the yellow wire from your gfx card to the video camera and then set it up like that....
If you have ever setup tv out I am guessing its very similar to doing that :D
Yes, a webcam can use usb and be used as a camcorder. He would be limited by the chord length, location of his pc, and by having to use the image on the screen as a viewfinder, not to mention subpar quality.
Edit: I read the post backwards, I am an idiot.
Have a look on the manufacturers website for a webcam driver. The little JVC one I've got needed a patch installed to work as a webcam.
It was the USB driver which needed patching for the cam to work as a webcam - USB streaming patch.
Which model have you got?
