Im having a bit of a stability/booting problem, basically, sometimes windows wont boot - it either hangs at the scroll bar or at the welcome screen, and occasionally just as it hits the desktop.
Im pretty certain the rest of the system is fine, I can run orthos for hours etc. Ive reset everything back to stock to be sure though.
I have to keep resetting the PC and eventually it will boot properly, and it will run perfectly.
Any ideas? Im sure its either the HDD or something to do with the SATA on the mobo
EDIT// I can hear it chogging and whirring, and all im using is IE, Is that normal?
