- 15 Aug 2007
- Outside in the bushes
Model Rocket Engines + Copper Pipe work a treat just make sure you stand well back if it goes horribly wrong!
For laughs, replace dead chicken with live one
I suggest a rethink of the original concept.
Find out how the canons work that "Human Cannonballs" use.
I think it is a strong spring in a tube.
Much safer, and any kitten you try it out with might survive.
As a project, and with the lighting a can of deodorant thread as inspiration, I would like to make a cannon as described above, fueled by lighter fluid or deodorant.
Will plastic drainpipe do, and how do I go about creating an end-pipe and ignition?
Thanks for any help![]()
