MT01XP said:I purchased the following from OCUK:
AMD Athlon 64 3000 Newcastle 130nm (Socket 754) - Retail (CP-070-AM)
However when I run CPU-Z it says I have a:
AMD Athlon 64 3000 Venice 90nm
How can I tell which CPU I actually have?![]()
Thanks in advance
trojan698 said:Maybe you got a venice instead. What are the codes on the top of the CPU?
Mul said:To be frank, it's definitely a venice. Not only does it state 90nm and venice, it shows E6 stepping and a core voltage of 1.392V. Newcastle cores are 1.5V.
Mul
Proudest moment of my life.
