Can i change my 2.16 core duo to a extreme edition?
26 Dec 2005
Paisley
Ive got a Dell X1710 - its amazing and brilliant, but i want it to be faster :P
Does anyone know if i can upgrade to the 2.67 or 2.93 extreme edition when they are released?
monkeypants said:
Is this in your laptop? And Core duo as in "Yonah" core?
If so, then no. No you cannot.
Yeh, thats right. I believe there is another CPU that is compatible though, is it called Meriom or something? Im totally clueless when it comes to this (changing to laptops totally got me out the loop).
Core 2 Duo "Meron" is the laptop chip, you can identify this one by the fact that it's socket 479 instead of 775, and it will have Txxxx part codes (T=35Watt, E=65W, and X=85W). In theory it should be compatible with motherboards that can handle the Core Duo, although I dont know if you would need a bios flash.
Core 2 Duo T5500 1667 MHz 2048 KiB 667 MT/s 10x --- 35 W
Core 2 Duo T5600 1833 MHz 2048 KiB 667 MT/s 11x --- 35 W
Core 2 Duo T7200 2000 MHz 4096 KiB 667 MT/s 12x --- 35 W
Core 2 Duo T7400 2166 MHz 4096 KiB 667 MT/s 13x --- 35 W
Core 2 Duo T7600 2333 MHz 4096 KiB 667 MT/s 14x --- 35 W
Cool thanks, when are the merom's available do you know?
No clue, but OcUK do sell the current 'Core Duo' range, so there is a fair chance they will stock the Merom as well. I believe they are scheduled for August release.
Are you still looking for a T7600? I might be able to help!
I can be contacted at (my name with a dot between the shaun and the brewer(at)totalise(dot)co(dot)uk
Shaun
