Basically i'm trying to fetch 11 gigs worth of itunes off a laptop HD and i can't do it via the network because the lappy is drenched in viri and simply wont have it. So i thought to myself, why not simply get the HD out of lappy and chuck it into the pc and grab them that way.. Alas thought the pins in the IDE cable don't fit. So, will it run on the floppy cable, or indeed is there a cable which i can buy that will convert it?.
Cheers, Ben
Cheers, Ben
