how much, sounds decent...Been offered this build, i5 3ghz, 16g ram, 240g SSD, 2tb HD, amd R9 270X graphics card and Win 10 Pro.
building is the easy part, loads of guides. just google.Thinking I might have a go and build my own. Never built one from scratch before but have change enough parts of them before so think I should be ok, any good guides or books out there ?
the problem is, if it doesn't boot on first try - then the troubleshooting. it's uncommon, but common enough to need to take it into account if you have enough expertise/time to spend on it.
or you want a system that "just works"
Slightly pricy, but not too bad depending on what i5 generation it is...£500 for that build.
