hey guys,
im giving my back garden a overhaul (new turf etc) and am wanting to get a structure in my back garden for a 125cc mito (temp bike) then a 600cc superbike
im also going to have a work bench and a large tool box as well as the gardening equipment.
ATM im thinking a 8ftx10ft metal shed/garage that i will be sitting on top of some concrete council slabs i have gathered locally.
the idea is to dig a small 8ftx10ft hole, fill it with sharp sand and dry cement, then level it off and leave it to set for a couple of days (moisture from the ground will set it off) after that, put a pile of dry cement on top of the slabs and brush it into the gaps between the slabs to fill it in and make it a bit more stronger.
the metal shed will then be bolted to the base that i made.
so what do you guys think?
the metal shed/garage is £300 a wooden shed in double the price.
thats the first thing, the second is bike security and shaving insurance prices.
so whats the best thing to do? bolt a ground anchor and have a huge chain?
also what can i do to shave some cash off the insurance prices?
thanks guys, looking forward to your input
