Bought a Macbook Pro last week with Snow Leopard. I'm not using the OS can I legally sell it?
Hi Lakitu,
What O/S are you using on your Macbook Pro if not Snow Leopard?
Thanks
Simon
Congratulations on wasting money.
Why so ? I'm running Windows 7 on a Mac, I bought the Mac with discount for it's build quality and its looks alone, having gone through 2 other laptops in as many years.
I see the MacBook Pro just like I see any other laptop. A piece of Hardware and this is was my favourite in terms of asthetics and durability.
I wanted to like the MacOS but being brought up on Windows I found it difficult. I'm quite happy to keep the OS on disc, just wanted to know where I stood legally.
Thanks. I am with you I do like the MacBook Pro for it design and build quality.
I was planning to buy one next year.
Did you have any problems loaded just windows 7; did it find all the drivers OK?
Thanks
Which model size do you have?
How do you find the battery life, do you see up to 7 hours use.
