Hi,
I have never built an SLI system so you will have to forgive my ignorance. I have a Nvidia 250GTS in my system at the moment, 2 spare PCI-e 2.0 slots, and a 9600GSO sitting around gathering dust.
As far as I can tell from using google, both cards use the G92 GPU (correct me if I am wrong), and as I understand the requirement of SLI is that both cards must have the same GPU, so could I use the 9600 to give my 250 a little boost?
If it is possible, my next question is: the 9600 only has 384MB, so will that mean that the 250 will only use 384MB of its 1GB thus actually hindering the total performance?
Many Thanks
Many Thanks
