Hello,
Recently I've been getting into the more 'Hardcore' gaming side of things, and finding most of my available time on online games, and as such I'm seeing the underperformance of my P4 3.4Ghz.
So, I think it may be wise to upgrade to a C2D.
I am unsure as to what my motherboard is, and what it allows etc. Basically my question is - If I buy a C2D, will it work with my motherboard currently?
I've been looking at ocUK's prices and they seem fairly cheap for the good reviews I've heard. Well, here's my CPUZ text report so you wizzkids can see if I'll be able to use a C2D with my current setup.
CPUZ REPORT: http://k3zzer.com/cpuz.txt
I will also be getting 2GB ram shortly, so disregard the 1GB ram and think 2GB
. If a C2D won't work with my current hardware, can you please tell me which piece of hardware(s) I will need to upgrade, and I'll try to do some research.
Thanks for all help so far
