Can I use headphones with my setup?
11 Nov 2006
I'm using the m-audio audiophile 2496 soundcard with Aego M 2.1 speakers, which gives me some rather lovely (and loud) sound. Unfortunately, I'm moving home from uni for the summer, and my PC is going to be in the living room, and my parents probably won't appreciate Iron Maiden drowning out the TV all the time. :p Headphones would be a great solution, but I can't find the right socket to plug them into.
I'm not really sure what I'm doing, but I think I need to somehow plug them into the back of the subwoofer. Is there anything I can get that'll convert the single plug on my headphones into the red and white plugs that'll go into the back of the subwoofer (if that'll get them working)? Or is there another way around this problem that I'm not aware of?
I suppose I could go back to my onboard sound for a while, but I've got so used to having great sound quality... :(
Hi there
well im sorry to say that you cant put headphones on the Ageo Ms they just dont have a socket to do this .as you say there very good speakers but the lack of a headphone socket lets them down . but if you do what i did you can get away with it . just get hold of a hub like this
Alright thanks. :)
Interesting... Is there a specific name I should be looking for?
And from that picture it looks like the cable connected to the sound card is plugged into the hub. Is that right? That would make things really simple.
Hello
yes thats right mate . you can even plug your mic in to it if you talk on msn or yahoo . do a search for a ( audio hub ) you can even buy them on the high street. prices are for about £7 to £10 .
