Can I use Iweb to design offline sites?
8 Jan 2010
London
As the question states can I use Iweb to make an offline site as whenever I try to save it keeps trying to get me to signup to mobileme. Reason why I want to use Iweb is that I just need to put together a quick offline site and I don't have any knowledge of how to use dreamweaver properly
Thanks for any help
If you click on your site on the left, it should give you the option to publish to mobile me, ftp, or folder. Pick a folder, then publish.
Go to the root of the site and you should see a 'Publish to' tab:
Change that to 'local folder' and job done.
