Dunky said:For AMD, tighter timings are more desirable than higher speed. But it's a balancing act between the two. Try and push the memory as much as possible (Speed wise) while keeping the timings tight and then slacken off the timings a notch at a time while raising the speed. Most non-value memory does 220mhz @ 2-2 (or 3)-2-5, after that you'll need to drop the timings - usually by 2.5-3-2-6 should get you to 250ish if you're lucky.
ted34 said:Only the very top 2ghz kits will keep to cas2 at 220. The only one i know that does that is the corsair 3500ll. 1gb kits can go fairly high now at tight timings
SH4RKY said:title says it all really... can memory thats rated at pc4000 be run at 3200s tighter timings??
eg;
can this:
OCZ 2GB PC4000 (CL 3-3-2-8 @ ddr500)
be ran at these timings:
OCZ 2GB (2 x 1GB) PC3200 (CL 2-3-2-5 @ddr400)
SH4RKY said:No, I havent decided on brand or speed yet, hence this thread.
So far though I've read that timings are more important than small overclocks, so I think I'll be getting a 3200 set and run a divider.
It's either the OCZ or the Gskill zx stuff.
Another question though, memory bought in america on my travels should work fine back in england shouldnt it??
I think the ram is a bit cheaper over there so it would be a bonus if it did.
