Can people help with my gaming computer custom build.
If i was going with the 560ti with the i3 could you please have a guess at what the framerate would be on ultra and on low (high) in crysis 2 as this is the game i play the most and if i know the framerate for that i could probably work it out for the rest of my games. Also is this power supply any good: Antec High Current Gamer HCG-400 - Power supply ( internal ) - ATX12V 2.3/ EPS12V 2.91 - AC 100-240 V - 400 Watt - active PFC
Or would i not be wise to go for a cheap power supply (as i think i could save a bit more money there) what wattage will i need for everything
Splash out on a 3570k if you can. overclocking is piece of cake on them, that'll cpu will last a good 4/5 years.
The Antec 400w is good, but not enough ommphh for the spec.
Please don't skimp on the PSU quality and try and use a 800w PSU that cost you a tenner from the local market.
The Antec High Current Gamer 520W modular is a great PSU (made by Seasonic).
These are good also,
http://www.overclockers.co.uk/showproduct.php?prodid=CA-053-CS&groupid=701&catid=123&subcat=1084
http://www.overclockers.co.uk/showproduct.php?prodid=CA-014-PP&groupid=701&catid=123&subcat=2179
Yeah never skimp on the psu, buy cheap buy multiple times with psus. :p
Get a decent one with a nice amount of headroom of say 600 watts and then if you get another upgrade itch you can get a more powerful gpu for example.
A good PSU will last years and years.
