- 26 Sep 2017
- In the Masonic Temple
I can see many many £50 and around cpu AIO's
Whats the difference? Which is best?
It's driving me crazy theres so many, I don't have time to copy paste everyone for the reviews
Some one please that is very savy and experienced which are the coolest and quietest or just tell me anything.....
Thank you
edit.
https://www.overclockers.co.uk/corsair-hydro-h55-quiet-liquid-cpu-cooler-120mm-hs-013-cs.html
https://www.overclockers.co.uk/cors...rmance-liquid-cpu-cooler-120mm-hs-039-cs.html
https://www.overclockers.co.uk/cooler-master-seidon-240v-aio-cpu-cooler-hs-078-cm.html
https://www.overclockers.co.uk/cooler-master-masterliquid-240-aio-cpu-cooler-hs-07d-cm.html
https://www.overclockers.co.uk/cooler-master-masterliquid-lite-240-aio-cpu-cooler-hs-07l-cm.html
https://www.overclockers.co.uk/id-c...on-all-in-one-cpu-water-cooler-hs-00a-id.html
This is only half the choices..............
edit_2
I need one that installs straight to the cpu, without having to put a backplate on the motherboard, the pc is already together.
Thank you
edit.
edit_2
