Ok, just built a system with these components.
Intel Core 2 Duo E8200
Gigabyte GA-P35-DS3
Corsair HX Series 520W Modular PSU
Seagate ST3500320AS 500GB Hard Drive SATA II
Point Of View 8800GT PCI-E Graphics Card
Corsair 2GB Kit 800MHz/PC2-6400 XMS2 Memory
XP installed, MB and Graphics drivers installed, no issues. Then I began to install a few of my apps that I have on my other systems. I have Zone Alarm with the updates on disk, so installed the first of those, no problem. when I went to install the update for ZA, I had a split second blue screen (page of white text with blue background) that was to fast to read ANY of it, followed by instant reboot. Tried again, same thing. Tested the file on another pc, works ok so its not corrupt. Tried to uninstall ZA, crash. ZA uninstalls fine in safe mode.
I have installed various softwares to test stability, like CPUZ, CoreTemp, Orthos and 3DSMark06. Ran Orthos Blend mode for hours on end without any errors, temps were at around 52-56 on full load (crappy stock HSF). Ran 3DSmark06 with no problem with a score of 11000+. No crashes or problems using any of these tools. Installed ConvertX2DVD, ran a few conversions, again, no problems what so ever. Booted with Memtest86+ and all ran ok, no errors. Ran a prog called BST to test the HD, all is good there too.
Have since done a fresh XP install, used only the latest drivers from Gigabytes site ect, same issue arises. so, what is the problem? Im trying to think what else has caused the crash to happen but my brain seems overloaded with nonsense now
Is it a software or Hardware problem here?
Gigabyte GA-P35-DS3
. Odd though, as its working very happy on my other systems
