hi, iv been trying to change from vista 64 bit back to xp as I prefer it but have had problems trying to boot from the disc drive.
I burned the iso image to a dvd r and put it in the disc drive, restarted the comp and set cd rom to the first boot device, went into hard disc priority and of the two things there i put 'bootable add in drives' over my hard drive.
when i press f10 and reboot, it says 'booting from disc' then a load of script flashes onto the screen for a second, including 'vista loader' and it boots vista.
iv tried taking the hard drive out and booting from the cd drive but it just says 'BOOT ERROR, INSERT MASTER DISC AND PRESS ENTER'
its not the dvd drive thats the problem as i have used 3, this one from a friend as i thought the other two might have been the problem.
my mobo is a p35 gigabyte:
http://www.overclockers.co.uk/showp...P35 (Socket 775) PCI-Express DDR2 Motherboard
im not sure whats going wrong, i installed vista 64 bit succesfully on this setup and it worked, i found the cd and put that in the drive and i can go into the setup through windows, but the same happens as with the xp disc if i try and boot it through restarting my computer.
does anyone have any ideas as to what is wrong or any suggestions to help me?
thanks
thanks
it wasnt responding when i pressed a key when it said press a key to boot from disc.
