Cannot get my Razer Diamondback to work.
6 Aug 2004
Essex
Hi,
I just got a Razer Diamondback mouse and it looks nice lit up, but i cannot get it to work.....
The left and right buttons work, and the scroll wheel is lit blue, but the lazer underneath has no lights at all, should it have?
I installed the drivers on my pc and my laptop, but this mouse does not work on either.
Can anyone suggest anything ?
Thanks in advanced.
No it doesnt.
I have an MX510 and a small Laptop Microsoft Optical mouse that both have this Red lazer beam.
Does this suggest its a duff mouse?
Razer Copperhead is a laser mouse, not optical, so there will be no visible light from underneath the mouse.
As to it not working, hmmm...if the buttons are working but the mouse can't move a cursor that does suggest a fault to me.
What surface are you using it on?
Hav
I use it on a desk with a mouse mat, but it doesn't work on either.
rapid64k, the mouse hasn't worked at all yet, except the left and right buttons and the scroll wheel.
I bought 2, for me and a mate, so i think ill open the 2nd packet and try.
Thanks for your help though.
