Canon D400 RAW Help
6 Apr 2007
Manchester
Hi,
Recently got a Canon 400D my first real camera, how do i set it to shoot in RAW mode i think i am shooting in jpeg at the moment, thanks in advance.
Pete
It's the top option of the first page of the menu! It's called quality, set that to RAW. If it doesn't let you then put the camera into something other than full auto (P Mode is fine) and try again.
Did they forget to supply a manual?
On my 350D it is Menu then tab 1. First option. Not sure if this is the same as a 400D.
