Canon lenses what to upgrade next?
13 Jan 2009
Have the itch to spend a bit more on my photography set-up. Currently have an entry level old 1000d, with a 50mm f1.8 lens. Mostly used to take pictures of my little one and family get togethers.
Happy to spend around 300 to 400, what would be the best bang per a buck upgrade?
1. New glass, have looked at the 85mm f1.8. Happy to consider alternatives.
2. Contemplating getting a proper flash, though I'm not sure how much this will add to my photography.
3. Have been checking occasionally the MM for a second hand canon body. Though not sure if I'd get more out of new lenses as opposed to a newer body.
All suggestions welcome!
Mostly will be used for pictures of the little one and family/friends. I'll do a bit more research on the lenses mentioned!
Went Park Cameras near Tottenham Court Road. Very impressed with the staff. Tried many lenses, but have whittled it down to either the 28mm F1.8 or 17-55mm F2.8. Probably going to go with the former, and upgrade the body to full frame next year.
Remember the 28mm will give you totally different pictures on full frame! I sold my 28mm f2.8 and got a 35mm f2 when I made the jump.
Some of the suggestions in this thread are almost as bad as in motors.
The guy has a 1000D and £400 to spend, why are you all suggesting huge heavy L-level lenses?
OP should buy the 24mm STM and a used Canon 85mm 1.8. Or just the 85 and a decent flash. Both can be used if he upgrades to full frame or he'd easily be able to sell the 24mm on.
