- 29 Sep 2007
- Sheerness, Kent, UK
Hi all,
OK, I've posted about this before but I've changed enough of my setup that I think a new thread is in order despite having the same old issue.
Basically, my 2nd PC can't connect to my wireless network no matter what I do.
I have an Edimax draft-N wireless card in the 2nd PC.
I have a Belkin pre-N wireless router on the 1st.
The setup *used* to work before XP SP3 came out but then had an epic failure. I have now upgraded to a Vista setup and still can't connect to my wireless network so wonder if anyone might have some suggestions as to what I can check/try to get my network working fully.
Cheers.
Cheers.
